PoulanPRO PP175G42 Lawn Tractor
1.4K views 1 reply 2 participants last post by  laser3kw
#1 ·
I have broken and replaced the link transaxle, (pc. 202) and found that the two mounting bolts (pcs 125 were loose causing transaxle movement and the breaking of the link. I noticed that the mounting holes in the brackets (pc. 172) were slotted thereby causing the possibility of movement, mostly up and down.
Is there a correct position in the slot for the bolt, a torque requirement, and is level necessary? Also how do I secure the 3/4"L bolt so that they
will not come loose again? Red Loctite did not work. Repair manual 115 78 02-49.
Thanks for any advice or opinions you can give.
george
#2 ·
Hi gera - welcome to the MLF
Usually, when a mechanism is engineered with slots, it is presumed that the mid-position is nominal. The slots are provided for assembly variation and end user adjustment if needed,
I would position bracket 172, initially, in the mid-slot position and as vertical as possible and then check for proper linkage movement. The link should move / swing freely and not change angle drastically. It should not exert usually force at full extent either. If it is shifting, I would use close fitting washers (smallest inside diameter) and sufficent large diameter on both sides of the bracket and chassis and use a Ny-lock nut to retain the clamp load. Get a grade 5 or grade 8 bolt if you wish for additional torque capability. As a extra step, once you are happy with the positioning and linkage movement, you can drill a small hole between the two slots, and through bracket 172 and the chassis and the screw a hardened sheet metal screw (or drill and tap for threaded screw) through to pin it in place.
Just remember, you have to figure out what is applying enough force to move it out of place first and then fix that.
good luck, keep us posted (with pictures too!)
