YTH150 Replacement Deck
1820 Views 1 Reply 2 Participants Last post by  Mark / Ohio
I've been fighting the rusting battle and lost Saturday. Part of the deck on the right side broke off and rendered it unsafe. I removed the blade on that side to finish cutting the back lawn with some difficulty.
A brand new deck is going to cost me over $300. I was hoping to find a used one cheaper. The exact model number is 954-14-00-07. what decks will fit this mower? Will a different brand also fit it? Can I get a wider deck?
Thanks for your input.
Welcome orion! :)
If the deck mechanically is in decent shape have you considered buying only the steel shell?
I entered the part number for the shell I found on this diagram page 42 & 43:
http://data.manualslib.com/pdf/8/746/74548-husqvarna/yth150.pdf?299bb3abd0cb23672a92f1f11ce85818
into Sears Parts Direct and came up with this:
http://www.searspartsdirect.com/partsdirect/part-number/532162809/0071/917
Lot cheaper if your other parts are still usable to transfer over to it. :)
