Hello,
My Craftsman 55 Series B&S Push Mower is stalling and smoking (white smoke) out of the muffler. This seamed to happen after I tried to mow some heavy growth in the rear of my yard. I did the following to try and correct the problem:
1) Changed the filter - it was soaked and clogged with black oil
2) Changed the oil
3) Changed the gas
4) Cleaned the carb. - the diaphragm was torn in one spot but I didn't have a replacement so I put it back. Do I need a new one?
5) I unscrewed the muffler. It is all "charred" near the center. Not sure if that is a problem.
What else can I do? I also noticed that when I pull on the starter it is hard to pull sometimes. I read that it could be a bent crank shaft. The crankshaft is $90+ to replace!!!
Any advice would be much appreciated.
Model 917.388190
B&S 4-Cycle engine model no. 10T802-1059-B1
Craftsman Rotary Lawn Mower
550 Series
21" Rear-Discharge
Thanks.
2) Changed the oil
3) Changed the gas
Model 917.388190
550 Series
21" Rear-Discharge
Thanks.
