Trying to fix a hard starting Scott’s 1642H. I’m nearly certain the issue relates to the valves; the mower won’t crank unless I manually rotate the engine past the compression stroke. I’m having trouble finding what the correct setting is for the intake and exhaust respectively. Can anyone point me to a good resource?
thanks!
UPDATE
Just pulled the valve cover and rolled the cylinder to TDC. From what I can tell there is no gap. I can’t get a feeler gauge between the top of the valve and the rocker arm on either intake or exhaust. First time doing this so I’m not entirely sure what I’m looking at. See picture below. Any pointers would be appreciated!
thanks!
UPDATE
