1 - 13 of 13 Posts
Nope, that part of it has wires. I'm wondering if it's a groun wire that attaches to a bolt? The rubber on the wire is cleaner near the end, as if it was in a connector.
manufactures stick to a wiring color code for consistency. Red 12v+ , black 12v - / ground, oranges ignition (maybe) yellow safety circuit (usually)
The length of the wire limits where it could be terminated. Th exposed wire may indicate that it was in a connector. What is the model and serial of the mower? I'll see if I can find a schematic.
Font Technology Electric blue Event Label
here is the schematic
the wire in your pictures looks to be solid red. If you can identify the plug connector it goes into and the other wires in that plug, you should be able to find it on the schematic
Is the mower currently working? starts and runs? all safety devices work or known to work?
Rectangle Schematic Line Font Slope
It won't turn over at all. I installed a brand new battery and made sure it was charged. Everything else seems to be functional and in good working order. I just installed a new blade engagement cable, and that is definitely on correctly. I'm assuming it won't start because of this wire being disconnected. The light by the key doesn't even light up when I try to start it.
Do you have a volt / ohm meter? It would raise our confidence if you could verify some circuit connections. Until till then, we are kind of blind and please use caution.
From what I see, I believe it is the 12v + feed to the power (key switch) circuit. It may have been crimped in with the big main battery 12v+ connection on the solenoid. I would crimp a ring connector to the loose red wire and remove the nut on the 12v+ battery connection on the solenoid, then secure it and the cable on that solenoid post. You'll have to determine which cable on the solenoid goes to the battery.
Good luck, keep us posted.
Rectangle Schematic Slope Line Font
Discussion Starter · #11 ·
I don't have one. But I'll give that a shot and let you know what I come up with. I'm hoping I can figure this out. Most people who work on these in my area are very busy.
Look for a connector like the one shown with the red wire going to it but this connector will be missing the wire. the wire is not very long so it has to be close. Good luck
Thank you. I looked up underneath the frame where it looked like the wire was pointing and I couldn't see anything. I may have to tear apart the body panel to get a better look.
1 - 13 of 13 Posts
