This is the sixth season I’ve used my mower for bagging leaves. Recently it randomly leaves behind a clump of leaves and or grass clippings. Prior to this it would vacuum up every single leaf and leave the lawn pristine. Any help would be great as this was the thing that sold me on this mower.
Are blades out of time
There are alignment holes in deck and the spindle pulleys. It’s in the manual. Basically blades should be 90 degrees to each other. When you position one straight in line the other should be perpendicular to it. Also check that deck is clean and no build up of grass on underside
