Hey everyone,
I've been maintaining an older lady's 30 inch Toro Time Cutter with the 8.75 B&S engine with OHV. She is really good about having me changing belts, changing oil, etc. It has the guaranteed to start Auto choke system. And to my amazement it always started on first or second pull.
She brought it to me today and it wouldn't start. Here is everything I did. PLEASE tell me I missed something!
1) Cleaned Carb. No blockage and gas was fresh. Auto choke was closed like it's supposed to be
2) Put 4 different RJ12YC spark plugs in and had them gapped to .020
3) Spark tester showing bright red light when I pull the rope
4) Compression test was 65 psi
5) Sprayed carb cleaner with the straw attached through the body of the carb, straight into the intake manifold.
6) Pulled magneto. Cleaned the magnets on both fly wheel and magneto.
7) Pulled OHV cover and just made sure valves were operating right. small wiggle on both rocker arms at TDC.
8) disconnected on/off switch just in case it was intermittingly shorting out
The most I ever got was 3 soft pops before sputtering out
I did not check the flywheel for timing issue because I wasn't getting any snap back on the pull rope.
Did I miss something? Please give me feedback.
Thanks
Tango
Thanks
Tango
