1 - 12 of 12 Posts
I got this Blower from a friend to see If I could get it going again.. He Straight gassed it and then broke the pull cord trying to get it to start again..
I Put a Wrench on the drive pulley and freed up the engine.. However testing the compression showed only about 2Lbs.. (1.75 to be exact)
However, I sprayed some starter fluid into the carb and hit the electric start..
And By Golly if that thing didn't start right up!!
-Stan :dunno:
Nice work!
As long as it still makes power and runs decent, keep on using it. :ThumbUp:
You may of had a leak on the test? 2lbs would be tough to get the right amount of air/fuel mix and compression to create proper combustion.
Sounds like it has a will to live though! Run it as long as you can ;) :2th:
No, My tester is spec.. I repaired the Pull starter and it feels like you are barely pulling an engine over.. It just spins..
The owner wrote it off as a loss so I suppose I will use it a bit over the winter..
It's incredibly small size makes it nice to do paths and things like that..
-Stan
Wonder if there could be a hairline crack in the head from it getting so hot?
Maybe, But I doubt it.. I think there would be oil visible like on other engines I've seen..
If I decide to keep it, It will require new paddles I think.. They seem fairly worn out.. And they throw a lot of snow out the front..
-Stan
I'll Put a new rope in the starter, Put on a new Primer bulb and screw the case together..
As I mentioned the customer Just did a write off and went and bought one of those new MTD Blowers with those Honda Copy Engines on it..
-Stan
Had mine out today and did my drive and the in-laws' dive and side walks. I'm always impressed by how much these little things will work!
Watched this other day Kori! Sweet little machine! Use it and enjoy the freebie! ;)
Tough little thing!!
1 - 12 of 12 Posts
