First off, Welcome to MLF!
OK, now lets see, if you have gas coming out of your carb while in non running mode, it is getting past the needle and seat. Check to make sure you did not put the needles seat in upside down or nicked it during installation.
It is possible that when you re-install the fuel line on the ribbed nipple on the carb that small pieces of the interior portion of the hose could enter the carb and get stuck in the needle/seat area. Always a good idea to put a fresh cut or replace the fuel hose from the filter (if installed) to the carb once you remove it. If the chamber overfills with fuel inside the carb that is where the fuel will come out as well as into the crankcase over time. You will find your oil level higher than usual.
I just had a 6.5 that looked overfilled by 3/4 a qt of oil, it was gas caused by a saturated float.
I'd recheck those areas. BTW, If you are not sure the seat goes in ribbed side first where the letter/numbers on the seal face out toward the needle.
