I am new to the forum.
I have a Briggs and Stratton Vanguard 15.5 hp model 28Q777 in a Toro Lawn Mower that doesn't run. I'm wondering if I can swap out with a Kohler Commander 15 HP Model CV15S Spec# 41515 (a friend has this and will let me have it).
Do shaft length and diameter match up as well as mounting holes and electric for starter.
Any help is appreciated.
Thanks
Welcome! The main issue will be wiring and exhaust. You will have to double check that the pulley stack from old engine will fit. Good luck!
:ditto: The wiring may be a pain to match up, as the engines are from two different manufacturers.
By the way, welcome aboard! :welcome:
The wiring is no big deal if you understand what each wire does. The connectors and wire colors may be different. If you have the wiring diagram for each mower and compare them side by side, it will be clear how to hook everything up.
