Hi everybody, hoping for some help.
2014 model. Solenoid clicks but nothing else happens. Starter motor was getting power, replaced starter with second hand part. Mower started. Switched it off. Now it won't start. Have charged the battery and engine is not seized.
Does anybody have any experience of this happening before?
Thanks for taking the time to read this
Check the interlocks... The most common issue I have with my Toro is that my wife forgets to switch off the PTO, and then the starter solenoid will engage but the interlock relay prevents voltage from getting to the starting motor.
Reactions: Scrubcadet10
Sorry for the delay in replyingi don't think it's the interlocks as when I have one of them 'on' the solenoid doesn't click.
Check to be certain that the grounds are tight and corrosion-free. If you have a battery load tester (the one below is about $20 here in the states), check to see if you're getting amps as well as volts from your battery. If not, you can try jumping it from a non-running car.
Automotive lighting Font Fashion accessory Metal Titanium
