I have a Professional G Series riding tractor. Recently I finished rebuilding the transmission --- a very bumpy and rough, long road --- and got the tractor going again. It has been idle for over two years, but it started easily but ran roughly.
I cleaned the carb and reset the needles, but the tractor stalls when I try to run at a higher speed when in "high" range. It works fine under low speed in the "low" range. I suspect it is not getting enough gas. The fuel filter is clean and I can see the gas trickling through it. Everything I can think of checks out.
Any suggestions or recommendations?
All responses appreciated, Thanks.
