I've searched but can't seem to find what i thought would be an easy thing to find on the internet. The foam portion of my JD seat(Milsco Brand) is completely separated from the hard plastic seat pan. It looks like some sort of hot hot was used in the manufacturing process to hold the edges of the foam to the pan. Has anyone found a fix or DIY to repair?? Im assuming this is common as my last JD did the same thing(not sure if it was Milsco seat or not).
FWIW: 2005 JD GX335
FWIW: 2005 JD GX335
