When I switched to an auto battery on my generator a few years ago in order to get the battery in the new NAPA battery box I had to tip the battery and be very careful the posts wouldn't short out on the generator's frame as it was going down into the battery box. I put plastic battery post caps on the old battery but still felt it was dangerous and a problem that needed fixing at some point.
This fall the battery I used went bad and I had to buy a new one so I thought this was the time to fix the problem....so I put a slitting wheel on my mini grinder and lowered the front of the battery box. Now the battery will slip into the battery box safely with room to spare.
Another thing I did was put put a small piece of rubber fatigue pad I had on hand in the bottom of the battery box to help eliminate vibration which destroys lead acid batteries.
Next spring I'm going to put the fatigue pad on my snappers battery holder and the 855's battery holder also.
I have the batteries on trickle chargers for the winter, it a nice felling when I can start the motors no matter what the temps is outside. The auto battery turns the 16 Hp Vanguard over like nothing. The smaller motorcycle battery wouldn't last but a year or two... can't have that on an emergency piece of equipment.
