ls their a link to find part numbers for my old A12 & C12 engines. l am looking for piston assy 3 Ring design. l know the #'s probably changed a few times naybe. Would the 604099 be correct one?
Thanks
Brian:help:
Piston id
Thanks for the reasurrance. these C12 engines on my 1956 models shows 2 rings plus 2 other grooves at top of piston without rings, my literature l have says that the early c12 engines have 2 rings and no needle bearings, what are the purpose of the 2 grooves?
Brian:2cents:
Ret. Moderator
Part # 601134 ... the part number you are referring to is a C19 engine 3 ring piston. For the A12 part # 602006 both standard 2 ring pistons .
Ret. Moderator
Brad you saw it on MTF when I got my schooling from Bald-Guy ... but the reference was between early 6252 and late 6252 "C" engines .
