Toro Recycler Model #20005. Need to replace the Mounting Flange Gasket (Drawing= #69 / Part # 37609) due to bad oil leak. Seems like a straight forward disassemble. Concern is reassembly due to oil pump assy and Governor shaft & spool. Will these stay in place & aligned when I pull the Flange mounting (Part # 37608) to replace the gasket. Any other "warnings" ? Should I give it a rest and let a Pro do it ? Thanks in advance !
