When I test the coil with a tester hooked between the plug wire and the head I get spark when I hook the tester between the spark plug wire and the spark plug I no longer get Spark
Welcome to MLF Mark. Are you grounding the spark plug to the engine block when testing or is the plug screwed into the engine?
Are you trying to find the reason why the engine doesn't run ?
I'd try a new plug first,
If that doesn't work, i would replace the coil.... i had a push mower that would shock the fire out of me when i touched the wire while pulling it, yet it wouldn't fire inside the engine, new coil solved it.
