1 - 20 of 25 Posts
Hello Jon and welcome to MLF! I've seen those before and unless someone else jumps in I'll see if I can find where I have a picture of one of those. You should be able to post a picture. Just use the advanced reply window and click on the paper clip (attachments) and follow the prompts. Just make sure the picture is not to big. You can also use the insert image icon on the top of the message box. It will open and you can insert the image address into it as well.
FP
As it turns out, it is a model 55, not an 85.
With a 5 HP Tecumseh. The carb is a blob of electrolisis. But some carb cleaner sprayed in it, and it started.
Where do you find the Carb #?
The engine numbers are as follows
TVM125 60246P C
DOM 4165 D
Tractor Model number 55 GA
IH Data plate Number 0300006U017831
Thanks,
Jon
Well,
I finally got some work done on my 55, When I got it cleaned up a bit, I noticed that the output shaft was out of line. So I thought well, I will open the transmission and either get a bushing, or make one. Well, it had more problems once I got it opened. Two of the gears are broken. The ones that connect the two shafts together with the chain.
Anyone have a parts transmission?
Thanks.
Jon
Discussion Starter · #16 ·
Five Points,
I haven't found any numbers. The only cast info is the word Foote and a patent number.
From what I have found online, it is either a dana spicer or a peerless.
It is from what I can tell, the same one that it illistrated in one of the other cadet 55 threads here.
I will get some pics tomorrow or the next day.
bwdbrn1,
Thanks, I think it is really cool as well. I was really bummed out when I found the broken parts in the transmission. The rest of the mechanicals are in such good shape.
Jon
Jon, without having a parts manual I believe the trannys are the same in the 55, 60, 75 and 95. I believe the 60 does not have a neutral safety switch though. I'm putting together some info on the tranny for you that I will post shortly.
Discussion Starter · #20 ·
Five Points,
That is great info, I already had the exploded view pic, but the rest of the manual with all of the specs is a wonderful thing.
I need a part # 5, 25, & 27. from the exploded view numbers.
Thanks again.
Jon
1 - 20 of 25 Posts
