1 - 11 of 11 Posts
This little mower was brought to the shop to be checked out for an oil leak. It has a 3.3 liter Cummins engine and all hydro. Found oil leak between bellhousing and block, so had to remove engine. Ended up having to remove all the lines off both pumps and leave one pump in chassis.:angry: Got our part fixed but the Toro dealer is having to come down and replace bad seal on front pump before I put engine back in chassis.
Once I got the pumps unhooked, was able to pull engine straight up and out. When the dealer dropped it off, he said they had sold an even larger one to the Biltmore Estate in Asheville NC. It had an enclosed cab, heat and A/C, and radio. All for the sum of 145,000.:eek:
WOW! What a price tag!
Sounds like a big job!
What engine is that Smitty? Diesel four?
1 - 11 of 11 Posts
