Hi,
I have a Craftsman 917378531. Its 7hp and a normal push mower. From what I can tell there is no spark when I pulled the spark plug out. I replaced the coil and also tested it with a multimeter and its approx 4-5k ohms. I checked the flywheel gap and its as close as possible without touching the flywheel. I checked the ground (between coil ground and flywheel) and it is about 1.5 ohms, basically very low. I cleaned off any surface rust from the coil and flywheel and I stuck the sparkplug in my edger and I can see the spark. I also set the stopper to not touch the flywheel and verified there are magnets in the flywheel.
So, I think the coil, sparkplug and ground are all good, but there is no visual spark. Is there anything else I should test, I believe I should be able to see the spark.
Thanks!
Thanks!
