Wondering what other uses you have found for your Mojack Lift. I have just purchased the Mojack Pro, lifting capacity of 750lbs. Have you come up with other things you can do with your lift besides your mower that will justify the cost?
Yup, anything that gets the work in the air makes things a lot easier!Im sure it could be used with an ATV if you have one, but i'm sure after a few uses lifting up the front of the tractor you wont be questioning if it was worth it or not.
Thanks. I'm starting to linger over here from mtf. Brad introduced me to it.Yup, anything that gets the work in the air makes things a lot easier!
Welcome to MLF Dan33Klein!
That's it, five point. Sears has them on sale now $125.00 off retail.:coolI believe this is what you have?
Looks like a nice set up.
That may be asking alot out of it..Do you think they are stable enough laterally to where if you had two, you could raise the whole unit like a car lift? :dunno:
Just got the new Mojack Pro Lift together. Rainy day here, so why not try it out? Easy to put together, worked like a charm on my X500. Wish I had it way before now.That's it, five point. Sears has them on sale now $125.00 off retail.:cool
Well thats a good start 89yt12! :coolI LOVE my mojack!!!!!!!!!
I didnt think it was that great untill I got one, now that I have it, I find myself taking better care of my blades and deck. It makes it super easy to get to the greese fittings under decks and the few that are under the Snapper. You can use the hand crank to raise it, or a 1/2 IIRC attachemnt on your drill. I personly find it just as easy to use the hand crank on it. I have the original one but it lifts the Snapper fine and its 550LBS.Well thats a good start 89yt12! :cool
Thanks!Have you found any other uses for it besides the mowers?
BTW thats a nice looking YT12 you have there.![]()
