has anyone used just map gas alone to braze ?...I just can't see buying a set of torches for all that I do with repairs...it wouldn't be much brazing maybe a bolt or whatever
It can be done but it's just barely enough for light duty stuff.
IMHO, The more expensive ($60-70??) oxy/mapp setup is the better choice but it's something that works great if not used very often as the oxy cylinders at $10 a pop are only good for about 10 minutes of work.
Reactions: wh55
:ditto:
I've only been able to braze very light weight metal with straight mapp gas. Heaviest I got to work was brazing the handle back on my garbage can lid which was basically two pieces of thin sheet steel. Other then that I repaired a garden fence and that was about it. It does seem to heat faster for soldering projects though.
