I acquired an old Lawnboy 5268 (I think it may be from the late 60's) and would like some info on it. There is a lever that slides in and out, located under the plastic gas tank. It appears to change the tension on a spring on the throttle. Is this supposed to be a low/hi throttle adjustment? Is it used for starting? Any explanation would be appreciated. Thank you in advance.
