Hey everyone,
I just got a LB Model 3002 from my brother-in-law. Is there anything special I need to know with this model of machine. I have worked/own alot of different models that have both D and F engines. This is my first C series engine that I have dealt with on a LB. This one hasn't been ran in a long time. I drained the gas tank as the fuel was close to being varnish. I pulled the bowl off the carb and cleaned it out as well. Put a fresh plug in it as well as cleaned the rest of the ignition system. Also, would the standard 32:1 mix be fine for it or should I run a 16:1 mix. Any help with it would be appreciated.
Thanks.
Stu
Thanks.
Stu
