Hi guys-
My 10515 has alot of hours, a heavily scored piston, leaking seals (top and bottom), but runs great with 121lbs of compression. It needs to be primed 5-6 times to get it to start.
a few days ago it started quitting randomly. It also starts back up,but seems to need to be primed in order to re-start. then it runs great again with lots of power for another 15-20m or so. If I had to say anything I would say it seems to run lean. Carb it clean as a whistle, and is a typical LB plastic carb with a priming bulb only.
Is this a symptom that my seals are finally gone?
