Welcome to MLF.
Have you check the spindles to make sure one has not seized up?
Check belts and idler pulleys as well.
Make sure there isn't a problem with the electric clutch.
Are the spark plugs clean? Replace every 100 hrs or once a year for them is a good rule of thumb.
Fuel filter clean?
Maybe run a little seafoam in your gas.
Could be a fuel flow problem depriving the engine of fuel under load.
These are just some suggested ideas for you to check out.
Let us know what you come up with.
Fuel filter clean?
