Kawasaki model FB460V
CODE FB460V-BSOO
SERIAL FB460-099786 The engine will not start back up again after the mower has been used for about 20 min. But it will start up after cooling down a while.
CAN anyone tell me how to pinpoint this problem? I am trying not to throw parts at this thing:help:
I'd check that your gas tank vent cap is not plugged. Also, the fuel pump might be worn/defective, causing it to quit working when it heats up. Another thing to look out for is a bad coil.
I had a similar problem and it turned out my sparkplug was failing, that was after I replaced the fuel pump...
Kawasaki FB460V after running the engine for about 20-25 min if i shut the engine off it will not start up again until the engine cools down.I am trying to diagnose the problem correctly the first time. Does anyone know the procedure? I'm able to use a multimeter. Also this engine is equipped with an igniter.
T:help:hanks G.MAN
I merged your post with your original and moved it to this forum for better coverage. :2th:
