I have a crack in the hood of my 345. Is there a good glue that will work with the plastic. Also my decal is coming loose, any good adhesive for that? Thanks
If the hood is made from ABS plastic, it will be embossed on the underside somewhere, pick up some Ambroid Pro-weld. You can find it online and if you have a good hobby shop they should carry it.
The grill on my truck is ABS, I used the Pro-weld to fix a few cracks it had and it did a great job. I can post before and afters of the grille if you'd like.
Reactions: Jackson
I shattered the hood on my jd a few years ago....talked to the mechanic at my local jd dealer , he told me he uses jb weld to glue the pieces back together...I tried it ,it does work... I just re-enforced the back side and sanded the top a little ,then primer and paint and you can't tell it was ever shattered...good thing I did have all the pieces
