I have a John Deere 240. It runs good just driving around. The problem starts after the blades have been engaged and you have been mowing for 30 mins or longer. When it acts up it starts to "bog" down or lose power. If you move the throttle control to "slow" it seems to help it out and will begin to run ok, but only for a short time until it begins to do it again. Or I can disengage the blades and it will seem to start running smooth again. Seems to only occur when the engine is warm, blades engaged and mowing.
I have done or replaced the following:
Cleaned carb
checked fuel solenoid
replaced carb gaskets
replaced carb float (had gas inside it)
checked fuel lines
replaced spark plug
replaced fuel filter
replaced air filter
replaced fuel cap
This is actually my dads mower and I would really like to get it running for him..
Cleaned carb
checked fuel lines
replaced spark plug
replaced air filter
replaced fuel cap
