Hello all I have an issue with a JD G345 with a Kawasaki FD611v Engine every few minutes it will start smoking really bad for about 15 seconds then run fine....I found that there is oil coming out of a tube from the crankcase into the intake kind of like a pcv and just burning the oil I was just wondering if anyone else has had this problem or could give me some ideas on a fix.
Thanks In Advance,
Mike
· Administrator
Welcome to the forum Mike. :)
Looks like you have already found out there are several references to others having the same problems as you on the net. (I saw your post trying to get a follow up reply from them.) But so far I have not saw any specific fix for it either. :dunno:
