Hi I have a j d 318 that surges.I was told to take off the intake & carb & to clean the carb & take the manifold apart & clean it & put Moto Seal gasket maker between the 2 sections of the manifold & that would stop the surging. Has anybody heard of this fix. thanks for your input. tom
Yup...I don't own the Onan eng...have heard of this routine...But< I would first try a quicker resolve...Remove the big bolt on carb bowl, drain the fuel, poke a wire straight in to ensure main jet is clear...Reinstall bolt...Test run...while spraying carb cleaner , carefully, on intake manifold, looking for change in eng RPM...if no change, then manifolds two halves are still sealed...If still surging,, will need to remove carb and overhaul it...
Thanks for the info, I was away for a little wife I had to help my wife, she shatterd her right shoulder & can't do much yet. Again thanks for the info I will try it tomrow. thanks again. tom
