2010 Bad Boy ZT 27HP Kohler
Main fuse blew when I pulled back to stop the mower (not running blades) just after cold start up to run down to the front gate. Turns out the ignition goes to ground when turning on the key. Blows fuse when turning on key, and confirmed with ohm meter continuity to ground check. Pulled every relay thinking it was something there, but always grounded when ignition on.
Also, anyone have a real wiring diagram that can be followed and not the one Bad Boy posts?
Ideas to check?
Ideas to check?
