1 - 1 of 1 Posts
The mower deck will rise and lower just fine. When I do the procedures to flip up the deck to service the blades, deck nothing will happen. The ball switch in the frame appears to be working because when engaged it will not allow normal lower and raise to work. The disengage lever/switch behind seat also appears to work also because normal lower and raise will not work.
I believe it is a switch problem but don't know if there is another switch besides the two I mentioned above. And how to trouble shoot or bypass the two switches above.
Does anyone have any ideas?
Thanks,
1 - 1 of 1 Posts
