Husqvarna Model #: 961450024 02 with a Honda GCV 160 engine
Changed the following with new:
Spark plug
Coil
Fuel
Air filter
Carburetor
Will not start and run, any suggestions?
Spark plug
Coil
Fuel
Air filter
Carburetor
Welcome to MLF Sarge.
Have you confirmed you have spark ?
Have you confirmed you have fuel flow through the carb and it IS going into the cylinder? ( spark plug should be wet )
Have you tried squirting a little gas through the spark plug hole or the throat of the carb?
Does the motor pop or even try to start?
Were you cutting the grass and the mower just stopped and wouldn't restart or has the machine been sitting for awhile?
The more info you give, the more answers you will get.
