Help!
This morning my fathers HRB developed a noise along with a related problem.
The noise only occurs as you engage the blade - it is a scraping like sound like a dried out bearing or partially engaged brake mechanism would make. Also if your don't engage the blade real slow the engine stalls.
I suspect that I'll need to tear the clutch assembly apart but though I'd see if anyone had any ideas first since not the easiest thing to do and last time I tore into something I found out afterwards a much easier way - a squirt of oil in the right place would have solved the problem in 5 minutes instead of taking 5 hours.
Thanks!
Thanks!
