I have a Honda HRX217 rear wheel drive with a GCV190 engine. The motor has never been removed.
There are 4 engine mounting bolts and 1 fell out and another one was loose which allowed the metal shroud to drop down a little and it started hitting the blade, etc...
Anyways, I thought that it would be easy to go to the hardware store for a bolt replacement.
So, I thought that the thread pitch was going to be metric, 8mm x 1.0 but I have triple checked all remaining 3 bolts and they are 5/16 x 24...approx length is 60mm=almost 2.5 inches.
So before I ruin the threads on the motor, I would like to confirm the OEM thread pitch and part#.
Thank You...
Thank You...
