Hi Everyone,
Just thought I'd run this by you guys. I bought a second hand Honda HRC216 K1, which I knew was running rough when I bought it. I have cleaned the carb, replaced the air filter, spark plug and oil, and it runs great for about 5 minutes. Then it starts surging and backfiring through the muffler, (after firing I guess to be correct).
It only happens after it gets hot, so maybe a coil pack? I am running Unleaded 91. I don't know if it is related, but once the motor starts to play up, the blades will not engage. While its cold, the blades cut quite happily.
Any advice appreciated!
Check your valves, too.
Intake Clearance 0.15 +/- 0.02mm ( 0.006 +/- 0.001in )
Exhaust Clearance 0.20 +/- 0.02mm ( 0.008 +/- 0.001in )
Reactions: Grunt
