I am having a problem with the manual transmission on my JD 180. All the forward gears are fine. When shifting into reverse it seems like the gears are not fully engaged. If you don't hold the shift lever it will pop out of gear. If I set the engine speed to low it works fine. The drive belt is fully stopped when the clutch is in so the transmission input pulley is not moving. Is there any way to adjust the shift lever to more fully engage the reverse gear or is this a problem internal to the transmission? worn reverse gear?
Any help would be appreciated
Tom
Tom
