Does anyone know what causes my 16.5 hp B&S Murray to not want to restart after it runs a while? Afeter it gets hot it will turn over after an initial hard try and then the starter just runs and the thing won't restart. If I let it set for an hour or so then it will start again. :confused:
Thanks
The next time it will not restart, check for spark. If no spark is present odds are fairly good the coil is faulty. I would also remove any engine shrouding and check for mice nests or other debris clogging the cooling fins.
