21 - 40 of 43 Posts
Discussion Starter · #21 ·
16166-Z8B-901 is what shows up for the GCV160LA1 S3B NH1... it's number 9 on the hondaparts carburetor diagram.
16166-Z8B-841 is the GCV190 part number for its emulsion tube... what Honda calls a Main Nozzle.
I will take a set of calipers to both and see what the actual difference is. It is interesting that the larger displacement motor has the numerically smaller emulsion tube... either the part numbers are completely arbitrary, or it is somehow referring to the outside diameter of the tube, itself.
A larger diameter emulsion tube would provide more of a restriction between the outside of the tube and the inside of the bore [where the fuel actually flows]... less fuel, smaller displacement... explains why the GCV160 has the '901 emulsion tube, and the GCV190 has the '841 main nozzle.
Is that your exact GCV160 model? There are many GCV160 models, you know...
  • GCV160 (Type A1A)(VIN# GJAE-1000001-9999999)
  • GCV160 (Type A2A)(VIN# GJAE-1000001-9999999)
  • GCV160 (Type A2R)(VIN# GJAE-1000001-9999999)
  • GCV160 (Type N1)(VIN# GJAE-1000001-9999999)
  • GCV160 (Type N2)(VIN# GJAE-1000001-9999999)
  • GCV160 (Type N7A1)(VIN# GJAE-1000001-9999999)
  • GCV160A (Type A1A)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type A1AE)(VIN# GJAEA-1000001)
  • GCV160A (Type A1AF)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type A1AS)(VIN# GJAEA-1000001)
  • GCV160A (Type A2A)(VIN# GJAEA-1000001-6699999)
  • GCV160A (Type A2R)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type A3A)(VIN# GJAEA-1000001-6699999)
  • GCV160A (Type BHH)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type E1A2)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type E1A4)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type E1G7)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type E5A4)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type EHHB)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type N1A)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type N1AF)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type N5A)(VIN# GJAEA-1000001)
  • GCV160A (Type N5AF)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type N5MF)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type N5R)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type N7A1)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type NBL1)(VIN# GJAEA-1000001)
  • GCV160A (Type R1A)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type R3A)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type R3A1)(VIN# GJAEA-8000001-8018819)
  • GCV160A (Type RTL1)(VIN# GJAEA-1000001)
  • GCV160A (Type S1A)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type S1A1)(VIN# GJAEA-1000001-6699999)
  • GCV160A (Type S1M)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type S3A)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type S3A2)(VIN# GJAEA-1000001)
  • GCV160A (Type S3H)(VIN# GJAEA-1000001-5386302)
  • GCV160A (Type STA1)(VIN# GJAEA-1000001-6699999)
  • GCV160A (Type STL1)(VIN# GJAEA-1000001)
  • GCV160LA (Type A1A)(VIN# GJAEA-5386303)
  • GCV160LA (Type A1AF)(VIN# GJAEA-5386303)
  • GCV160LA (Type A2R)(VIN# GJAEA-5386303)
  • GCV160LA (Type E1A2)(VIN# GJAEA-8018820)
  • GCV160LA (Type N1AF)(VIN# GJAEA-5386303)
  • GCV160LA (Type BHH)(VIN# GJAEA-5386303)
  • GCV160LA (Type N1A)(VIN# GJAEA-5386303)
  • GCV160LA (Type N5AF)(VIN# GJAEA-5386303)
  • GCV160LA (Type N5MF)(VIN# GJAEA-5386303)
  • GCV160LA (Type N5R)(VIN# GJAEA-5386303)
  • GCV160LA (Type N7A1)(VIN# GJAEA-5386303)
  • GCV160LA (Type N7S1)(VIN# GJAEA-5386303)
  • GCV160LA (Type R3A)(VIN# GJAEA-8018820)
  • GCV160LA (Type S1A)(VIN# GJAEA-5386303)
  • GCV160LA (Type S1M)(VIN# GJAEA-5386303)
  • GCV160LA (Type S3A)(VIN# GJAEA-5386303)
  • GCV160LA (Type S3H)(VIN# GJAEA-5386303)
  • GCV160LA0 (Type A1A)(VIN# GJARA-1000001)
  • GCV160LA0 (Type A1AF)(VIN# GJARA-1000001)
  • GCV160LA0 (Type A2R)(VIN# GJARA-1000001)
  • GCV160LA0 (Type BHH)(VIN# GJARA-1000001)
  • GCV160LA0 (Type E1A2)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N1A)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N1AF)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N5AF)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N5MF)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N5R)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N5RB)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N7A1)(VIN# GJARA-1000001)
  • GCV160LA0 (Type N7S1)(VIN# GJARA-1000001)
  • GCV160LA0 (Type R3A)(VIN# GJARA-1000001)
  • GCV160LA0 (Type S1A)(VIN# GJARA-1000001)
  • GCV160LA0 (Type S1M)(VIN# GJARA-1000001)
  • GCV160LA0 (Type S3A)(VIN# GJARA-1000001)
  • GCV160LA0 (Type S3H)(VIN# GJARA-1000001)
  • GCV160LA0 (Type S3T)(VIN# GJARA-1000001)
  • GCV160LA0 (Type SBT)(VIN# GJARA-1000001)
  • GCV160LE (Type A2A9)(VIN# GJAAE-1000001)
  • GCV160LE (Type A4A9)(VIN# GJAAE-1000001)
  • GCV160LE (Type A7H1)(VIN# GJAAE-1000001)
  • GCV160LE (Type N7A1)(VIN# GJAAE-1000001)
Discussion Starter · #23 ·
Yeah, GCV160LA1 S3B NH1 is on the barcode sticker on the back. It's on a Craftsman M250 push mower, if that means anything.
Did Honda actually put a closed loop PCV system on the GCV's? The breather tube appears to lead to a bowl inside the air box... to feed crankcase oil vapor back into the combustion chamber, I suppose.
Does the carb/intake actually provide vacuum to pull crankcase gas through this system?
Could one simply put a valve cover PCV filter in place of the breather tube? Assuming that it doesn't interfere with the throttle linkage? I cannot guarantee the factory air box and filter will continue to be used, so this breather system may need to change, as well.
Discussion Starter · #25 ·
I figured as much. Thank you.
I'm seriously considering running a little conical dirtbike airfilter, and thought it would be pretty slick to have a matching, although smaller, conical filter next to it on the breather. If I am feeling squirrelly, I could even possibly modify a crankcase breather cover with a valve cover breather kit.
By the looks of it, the breather hose is just inserted through a hole in the breather cover, and is left unsecured inside.
Discussion Starter · #26 ·
The Honda/Keihin "constant velocity" carb is an interesting piece to use on a lawn mower, me-thinks.
It [the Constant Velocity Keihin carb] has an emulsion tube, which is something Weber has developed extensively to modify fuel curves... generally to provide mid-range adjustments. A lawn mower has no mid-range to adjust.
And this is not the same CVK casting/body used on dirt bikes, so to carry over that emulsion tube has to be for some economy/emissions gain. My only assumption being that literally any measurable emulsion allows smaller jets to be used, overall. I wonder if Weber emulsion tubes fit... that would be neat.
Has anyone bother re-jetting their push mower carb? Particularly a GCV160/190 carb?
The demand of a 160cc engine @ 3500rpms is similar to that of a 70cc engine @ 8500rpms... and such engines are using #80 main jets, #40 pilots. The GCV160 has a #55 main jet from the factory. The GCV190 has a #65, for reference. Both the GCV main jets seem on the lean side.
I have already ordered the #65 main jet for my GCV160, which still seems to be leaving very little margin of error, all things considered... especially if I plan on turning up said GCV160 to ~3600rpms.
Would a richer main jet, something like a #80, have any sort of cooling effect? Every little bit helps with an air cooled engine (especially one without an oil pump/cooler).
Discussion Starter · #27 ·
To answer my own question, yes. You can jet the carb rich to effectively make the engine run cooler... this process is used quite a bit in aviation as well as 2-stroke dirt bikes, and is called "rich of peak".
In this regard, I may very well order a 080 main jet to try. Honda has 99101-124-xxx main jets ranging from #48 to #150, so we have options. I have found #35, #38, #40, and #45 pilot jets, and can only assume there is also a #42 available, too [although I didn't bother searching for it]. And three different emulsion tubes available, but their differences remain a mystery to me. There are quite a few different CVK adjustable fuel mixture screws out there... I hope I can find one that works, although it really isn't the end of the world if I cannot.
It is just a push mower, not a pit bike...
The Federal Government set the engine RPM specification according to the length of the cutting blade for operator safety. It is called "Blade tip speed". A discussion can be found here what blade tip speed | Lawn Mower Forum and more info doing a Google search, if your interested. The blade is a highly rotating piece of steel that can cause severe injuries or death if pushed beyond it's limits. As you said, it is just a push mower, not a pit bike.
Discussion Starter · #29 ·
Interesting... it would appear ~3500rpms is about as fast as I can go with a 21" blade... according to the "revised" standard of 19,000fpm. A 21" blade could be spun to ~3800rpms using the old standard of 21,000fpm. Not sure if the blades are actually made any different between the two different sets of standards, or how significant that 2,000fpm difference really is.
Something being flung out the chute is going to hurt, either way, but I doubt the difference is truly that significant. Blade harmonics might be a factor, but even cheap manufacturering and metalurgy processes today probably produce better blades, overall, than when the standards allowed higher tip speeds.
Who actually even knows which tests were used to establish or revise these standards, anyways? They could be completely arbitraty BS numbers established so insurance companies have an excuse not to pay.
Discussion Starter · #30 ·
In the name of science, would increasing just the pilot jet size enrich the entire rpm/throttle position spectrum?
Pretty sure the idle circuit is always contributing fuel, and I was wondering to what extent does the pilot jet affect full throttle enrichment?
Discussion Starter · #31 ·
Meh, found an answer to my own question...
It appears that a typical idle circuit only contributes about 15% [at most] of the overall fuel during full throttle.
So, huge changes in pilot size (~30%) amount to quite small (~4%) changes in overall fuel at WOT... not at all a significant amount of tuning available from messing with pilot jets, alone. I doubt one would even able to notice a difference at full throttle without equipment specifically designed to detect minor changes in AFR... it MIGHT be detectable with EGT sensors, but I doubt it.
Discussion Starter · #32 ·
Would there be any benefits to adding Honda's little vacuum powered fuel pump to a lawn mower? The 16700-z0j-003 pump appears to be standard on some other GC160/GC190 models, as well as GX engines.
Although it provides yet another component that could potentially fail, I am relatively confident in the simplicity of the mechanism to last for what I would be asking of it. I could even isolate the pump, itself, from vibration with a creative mount utizing rubber or polymer spacers... if such measures might be remotely necessary. The generators that use them do not seem to go through such efforts to protect the pump from vibrations.
Again, I don't know if there would be any benefits... other than possibly guaranteed fuel supply on ridiculous sidehill runs? Pick a different approach. Lol. And, if the whole mower is that tilted, the pickup location of the tank could be above the level of the fuel in the tank, and no pump is going to solve that.
Would there possibly be any drawbacks associated with installing a vacuum operated fuel pump?
It's not like that vacuum signal ahead of the ventruri/butterfly is being used for anything else... nor will tapping the intake to access that vacuum signal weaken or otherwise affect the function of the carburetor downstream. So, I don't see anything wrong with delivering an ever so slightly more consistent supply of fuel... obviously the vacuum operated pump does not overpower the float/needle, given that this exact pump is mounted on various other models within the same family of engines that I am tinkering with.
Discussion Starter · #34 ·
That is a good point about the seat being different... even if one was to get the needle and float out of a carb from an engine with a pump. I am not too worried about adding a vacuum operated fuel pump, it was just a tinkerers' pipedream.
In other news, I found a 4th emulsion tube part number in the same class or family as the others for the GCV160/GCV190 carb(s). This newest one [that I found, not sure if it is actually any more recent] breaks from the naming convention used by the first three I found... those first three end in 841, 901, and 911... that newer, 4th one I found ends in WA1. Yet, it is still part of the same 16166-Z8B family of main nozzles.
Harley Davidson used to use CVK carbs, and I might be able to find more answers into decoding these mysterious devices snooping around in that community. Not that it will do literally anything for a lawn mower, either way. Lol.
Discussion Starter · #35 ·
The four emulsion tubes in the 16166-Z8B family seem to be the same shape/diameter... close enough that I would have to get out my calipers to find any difference, if there is any.
All "rows" runs vertically along the emulsion tube between an upper and lower shoulder. Each row is spaced 90* apart, around the emulsion tube. If the rows do not contain the same number of holes, they alternate in order around the emulsion tube...
The 841 has two rows of four holes, and two rows of two holes.
The 901 has two rows of four holes, and two rows of three holes.
The 911 has four rows of five holes.
The WA1 has four rows of six holes.
The 841 and WA1 have two ports at the bottom, below the lower shoulder that I believe would supply more fuel to the pilot circuit.
The 901 and 911 do not have the extra ports below the lower shoulder.
When I get a chance, I will try get some halfway decent pictures posted of each emulsion tube to show the size and vertical spread of each row of holes.
Discussion Starter · #37 ·
I'm trying to decide between the 841 and the WA1... for whatever reason, I really like extra ports below the lower shoulder. I just cannot decide if switching from the pilot circuit to the main circuit sooner is good or bad for a lawn mower.
The way I see it, a lawn mower has literally zero mid-range. So maybe switching over to the main circuit as soon as possible would be best. The WA1 has ports at the same level as the fuel in bowl, this port location makes the switch from pilot circuit to main circuit happen sooner... soonest possible, actually.
The 841, on the other hand, specifically has no holes in the middle of tube... avoiding the level at which the fuel is sitting in the bowl. This port arrangement delays the switch from the pilot circuit to the main circuit. And I do not know if this would be better (or worse) for a lawn mower.
My lawn mower spends literally zero time at idle. I start it, and I start mowing. Choke is still warming up, I'm already mowing. Choke opens eventually, and I have already mowed half my front yard (it's small). The quickest way to warm the engine up is using it... I don't mess around.
Do you think the quicker switch from the pilot circuit to the main circuit of the WA1 would be better than the delayed switch provided by the 841?
I'm probably going to stick the 0650 main jet in there, regardless, and just turn up the governor until she purrs like a kitten. And, knowing me, I will more than likely swap out the 901 emulsion tube that is said to be in there now, with either the 841 or WA1, at the same time as changing the main jet.
Without changing the pilot jet, or having an adjustable fuel screw [yet], I think jumping to the main circuit the quickest would be my best bet, right meow. She starts fine... pilot jet works, automatic choke works... and she spends absolutely no significant time at idle.
Discussion Starter · #39 ·
It was warm and sunny for a few days in a row, so I mowed the lawn. Probably still too early/cold, but it's already done.
I hadn't ran the fuel out of the bowl last time I put it away, so I wanted to do that... even if I had just kept it stored in the garage without mowing. Between this mowing [last weekend], and the one before it [a few months ago], I had drilled like sixty 1/8" holes in the air filter cover. I have been anxious to use it since drilling those holes... it's already jetted so lean, increasing airflow isn't going to improve that any. Lol.
I did mow the front and back yard, non-stop. Didn't big down on me a single time, and the grass wasn't even totally dry. For it being the first mow in over a month, I am impressed. Maybe those holes actually helped... she usually will die if the chute gets clogged up with wet clippings. Every time I noticed there was nothing being ejected out the chute, I would just rock her back and forth to get all that $#!+ to fall out the bottom... but I had the opportunity to notice instead of her quitting on me.
PS. I in no way think drilling those holes in the air box did much of anything. I just like to tinker...
21 - 40 of 43 Posts
