I swapped an 18.5 hp, twin cylinder briggs onto my JD 111. The old motor gravity fed fuel into the carb, the new motor has a fuel pump. It ran and mowed great last weekend. This weekend I got half done and it quit running. The motor quit getting any fuel and there was fuel leaking from the carb through what I would call a weep hole on the back of the fuel pump.
Should there be a problem using the gravity feed tank with the fuel pump motor, will fuel continually flow from the weep hole, or does the pump need rebuilt?
Thanks, Tom
Thanks, Tom
