Greetings:
I have a 757 Ztrak with 800 hours, this is a new mower for me, it's my first season with it. Works great, I bought it used from the JD dealer nearby and I've been thru it fairly carefully to clean the dirt plugging the fins, new hydraulic oil, engine oil, filter, etc, etc.
I've noticed that the fuel pump appears to be pushing very little gas into the filter, just a very weak stream. The filter is empty. The mower for the most part appears to run strong when under load, but last evening it started bogging severely. I suspected the vac line because its getting old so I replaced temporarily with a made-up line and it started running again. So out to mow I went. Started bogging again and I mowed with it like that for a minute or so and it straightened out.
So the question is, how much of a fuel stream should I see in the filter when running? Again, there is no fuel visible in the filter, just a very weak thread of gas coming in from the tank. Obviously, running the mower lean will run it hotter and these things are susceptible to overheating anyhow what with the plugging of the fins. I don't think the mower has been overheated, I have 85# compression in both cyls...
Thanks for the help!
BTW, these forums are super!!!
