Foote-Dana Transaxle Troubleshooting Guide
9852 Views 1 Reply 2 Participants Last post by  Larry Rarus
HOPE THIS HELPS WITH TRANSAXLE DIAGNOSTICS.
THIS IS FOR THE INFAMOUS FOOTE-DANA 5 AND 6 SPEED TRANSAXLES
Here is a troubleshooting guide which I had in a document, don't know if it will help:
Problems with Gear Drive Transmissions
Transmission surges or lurches while in motion
• Shift keys are worn. The keys loose their "spring" and allow the mating gear to slip around it, causing the jumping condition.
Transmission is extremely hard to change gears.
• Input and Output shaft bushings are worn. Replace with new ones.
• Rust on the input shaft. Caused by moisture in the case. Disassemble transmission and clean, replace any hard grease.
• Shift detent balls over adjusted. The one or two set screws next the the shift lever control the pressure on the detent balls. Back the screw off and reset them so the screws are just a little snug when you tighten them down.
Transmission won't move in certain gears.
• Teeth are cleaned off of input/output gears. This happens when you "dump the clutch" when taking off. Also, changing gears without completely clutching will damage the gears.
Won't Move.
• Input shaft and/or bearings are worn. The input pinion is not properly aligned with the mating bevel gear, causing the input motion not to be transferred to the other gears. Caused by normal wear or excessive tension on the belt.
Won't Stop.
• Brake is out of adjustment. Some MTD transaxles use a castle nut and a cotter pin to keep the nut from coming off. Remove this pin before adjusting. With a half inch combination wrench, reach under the right side (most tractors) and tighten the nut until you cannot push the tractor. Now back that nut off until there is slight resistence when pushing the tractor. If this does not fix the problem, see below.
• Brake pins are stuck. Remove the nut and loosen the right bolt that holds the brake assembly to the transmission. Remove the metal retaining piece and the brake lever. Now remove the other bolt and remove the pad housing. Remove the brake pad and the metal protector. If the pins are stuck, use a pin punch to remove them. Now with pliers, clean up the pins by using a wire wheel on your bench grinder or you can use a hand wire brush. Clean the housing with carburetor cleaner and apply Anti Seize to the pins. Re assemble in reverse order and adjust the brakes.
• Grease on Pads or Disc. Follow directions above to remove the brake pads and replace them. Remove the brake disc to replace the pad behind that. Clean up any grease leaking from the case. Clean the brake disc with a good carburetor cleaner.
• Broken brake disc. I have seen this happen on Foote transmissions with an internal brake disc. The transmission must be taken apart to fix.
IF I SHOULD RUN INTO ANY FURTHER DATA ON THIS SUBJECT I WILL POST IT......GOOD LUCK!
How much grease?
Sorry if this is a repeat question. I've searched the site but didn't get any hits.
I am in the process of rebuilding a Foote 4360 on a Roper lawn tractor. It cleaned up very nicely and looks like new inside now. Every place I've searched simply says to grease the transmission but no one ever says how much. Apparently the part number for the grease is simply 4300 and it's readily available in plenty of places, even Sears. It's sold in a 16-ounce container. But again....how much is actually used in a bone-dry, squeaky-clean, just rebuilt transmission?
