Have a new 6 hours, with Briggs Vangard, just noticed oil accumulating on bottom of frame under engine, can't seem to find where it's coming from. Checked all quick connects on oil tank and engine, seem fine. Hope it's nothing serious.
Hopefully by 12 hours a dry seal someplace will swell up once hot and wet and do it's job. Certainly not something you want to have to deal with on a new mower. :(
Looks like it is fuel coming out of fuel vent filter when both tanks are full and mowing on rough terrain. I placed a hose on open barb on vent filter and ran it down below frame, seems to have cured the problem. WTF?
As long as there are no random drips going onto the turf you should be OK. Could you point the exit toward the sky? Even if you had to put a small extension on it just to be safe during the hot season.
Finally found problem , did not take it to dealer, too much of a hassle. The seal between oil bypass cap and engine block was missing. Installed seal from a Briggs oil Filter I had in stock and problem solved, will request compensation from Briggs&Stratton. Number 1599 in drawing was missing
Automotive tire Wood Tire Wheel Gas
Automotive tire Wood Gas Circle Automotive wheel system
Wood Rectangle Font Material property Wood stain
Font Auto part Rectangle Parallel Drawing
