Is it possible to put a Kohler 20 HP Command engine (currently in a Craftsman mower) in a Fastrak 36" mower? The original engine is a SV470S (15HP Courage) Thank you.
Well, I'd check the shaft size first; that's a prime consideration in an engine swap. The bolting pattern is probably the same, but you never know. If you can get the same shaft size and bolting pattern you should be all right.
