Hi everyone, can you help me with this issue. The engine (20HP Briggs,441577) runs smoothly only when the choke is pulled at least half way out. If the choke is pushed in, the engine will die. I have seen this issue on other engines so my question is.... what most likely is the problem? Thanks is advance for your suggestions.
WTC
WTC
