This is genuine John Deere Service Advisor EDL v3 Kit(replaces EDL v2). The product comes in a plastic case. The edl kit also includes the V3 Wireless Adapter, W1 Connector Cable DS10150 and the USB cable. There is not diagnostic software included with this item. If you need it, it can be purchased optionally. The links for the appropriate products located below.
Multifunctional John Deere dealer diagnostic tool is designed to serve the construction, agricultural and forestry equipment, as well as various engine technology produced by John Deere.
John Deere EDL v2 version has been replaced by JD EDL v3 kit. New EDL v3 kit doesn’t work with Service Advisor 4.2 version.
John Deere EDL v2/v3 drivers are built-in with Service Advisor application. Please do not try to install the driver by with yourself, using the setup files from any not reliable sources may lead to unstable work of your windows OS.
Important Notice. In some cases, after Service Advisor Setup the EDL drivers may be installed not correctly (the yellow exclamation mark near driver name) or even missing. The main reason is your anti-virus application or windows system settings. For this purpose, JD officially released the hotfix that allows reinstalling only the EDL driver. Please contact us for more information.
The communication unit s a part of the John Deere Service Advisor system
Functions and technical capabilities of John Deere diagnostic adapter:
– Troubleshooting;
– Setup and Calibration ECU;
– Interactive tests;
– Computer programming;
– Diagnostic Code Reader, and much more.
This scanner is compatible only with specialized software JD Service Advisor 5.2.461 or higher.
This product includes:
– Storage Box (Part # SA5025)
– USB Cable (Part # SA5026)
– DS10150 (Part # DS10150)
– EDL v3 Wireless Adapter (Part # SA5022)
The EDL (Electronic Data Link) v3 diagnostic adapter kit works in cooperation with the dealer software JD Service Advisor™.
With Service Advisor™ you can view service manuals, use DTAC (Dealer Technical Assistance Center) data, make diagnostics, readings, tests and calibrations, re-program controllers.
The most up-to-date versions of the software(The Service Advisor software is not included in the EDL kit; you need to purchase it separately):
JD Service ADVISOR 5.2 [2020] AG (Agriculture and Turf division),
JD Service ADVISOR 5.2 [2020] CF (Construction and Forestry division).
For notebooks running Windows 7/8.1, we can provide the previous version of the John Deere Service Advisor software (4.2)
John Deere no longer supports the Service Advisor v4.2. The last DATA update has been released in June 2016.
But due to lower system requirements (smaller amount of RAM and HDD space), old Service Advisor may be useful, as it supports all the JD models with up to 2016 release year and works great.
John Deere Service Advisor 4.2.006 – Construction & Forestry With History DVD 5/2016 no longer supported by EDL v3 kit
John Deere Service Advisor V 4.2.005 AG Agricultural Machinery 05/2016 With History DVDs no longer supported by EDL v3 kit
Optional products(we will gladly offer you the best price in case of bulk order):
W1 Connector Cable for John Deere
W2 Connector Cable for John Deere
W3 Connector Cable for John Deere
W5 Connector Cable for John Deere
W6 Connector Cable for John Deere EDL v2
W7 Connector Cable for John Deere EDL v2
W9 Connector Cable for John Deere EDL v2
W12 Connector Cable for John Deere
W13 Connector Cable for John Deere
SA1002 Interface Cable for John Deere
– Troubleshooting;
