My Prestige electric heigth of cut motor is not working after 150 hours. It is getting electricity, just not turning the auger. Is there a manual override? It was set at 1 inch for winter storage. I need it back to 4.5 now.
Not really familiar with that type of machine, but I would say that there probably would be some sort of override. Possibly operated with an open-end wrench?
Might have to pull the motor off and see if it will turn then. Might also try tapping on the motor while electric is applied. If your lucky the tapping might un-stick an internal brush or bearing and get it running. Looks like they are about $200 to replace.
if you can take the bracket off and get at the trunnion that goes up and down on the screw you may have bottomed it out to the end of the screw and it needs to be loosened up. It might be a left hand thread but just try and break it free being easy on it turning it one way or the other and then try and see if it turns once it is loose before you piut it back together.
