Hi ,
I have a 1997 [Huskee], MTD, Model 14AS833H131, 18.5 hp, 46" cut.
The drive belt is worn out after many years of use, I ordered the belt that shows to be correct 954-0461, 7/16"x78.25"
It is over 3" too long. I took the old belt off and measured it and it is 74".
I am not sure why there is such a difference.
Also you can see in the picture the belt as it comes off the transmission pulley it goes under a small metal roller, I have never seen a setup like this. is this factory?, or should the belt go straight to the engine pulley on that side?
Any help would be appreciated.
Dean
Dean
