Welcome Road69runners. :howdy:
Could be either the clutch is not getting power to it or has failed. First I would check the wires to the clutch and try to follow them back up to the switch or relay someplace and make sure no wires look broken or have loose connectors. Also if you have a voltmeter try to determine if 12Vdc is making down to the clutch.
(Might want to pull the deck drive belt back off in case the clutch surprisingly activates while your are troubleshooting it.)
